ludecrasy87
Ok so ya i finally got my D15B i live at Las Vegas, and i headed to Burbank CA to pick up my engine w/ the P08 OBD1 then whe i was pullin my truck round the corner they told me if i will like the tranny for the engine they sold it to me cheap just 100 extra. Because they said they needed to make room for the upcomin products.
Now my question is that i own 90 DX will i be able to use the axles out my DX tranny?
If i wanted to purchase performance parts for this engine do i order them for 92-95 civic, also do i order the same as i would for regular parts cuz planning to replace my oil pump, timing belts and other stuff.?
Also when i install the engine and i already converted DX harness to MPFI for everything to work right do i just remove the injector resistor box for it can be right?
Oops before i forget i followed a guide on converting the DPFI to MPFI for a ZC engine swap is everything the same?
