trans/clutch Q.
jamesA
Thank you for your business.
VIP
I was reading around on HT and got to thinking...
if I get a jdm itr 5 speed, would an ACT clutch meant for the S4C bolt onto it? If not would a clutch built for the c5 S80 fit onto it?
Basically James any hydro clutch meant for the ITR should work. As long as the flywheel is for a Hydro Trans you'll be ok.
a'ight. thanks guys. just wanted to make sure before i spend 500 on a clutch and it for some reason not fit.
