ok i have a isue i just installed a new trany and i dont know wich one it is.
ok heres what i know i had a cable ls trans that had a small spline had no markings on it some ricer tried to polish it
new trans was told it was a ls it came out of and ls is marked ys1 with a obd1 style label and has a larger spline than my old cable trans so im guessing that it came from a 92-93 and my old one was a 90-91
so wha ti want to know is whiit one has shorter gears and have i maby goten my hands on a gsr trans i dont know also if this helps for you trany gurus it has two screws on it that hold the ball berrings that hold the shift forks in gear. un like some of them where they are built in to the fork its self are the any other things that i can look for like one other thing it has a washer on one of the shafts that has a tab sticking up off it and locks in to trany case when it is installed it is right under the berring im assuming that it keeps the inner shaft from spining
i don o i just want to know and i cant drive the car yet
