Trans rebuild????
Discussion in 'General Tech and Maintenance' started by ep3moschini, Mar 5, 2007.
  1. ep3moschini
    ep3moschini I R T3H NO00Bz!
    Northbridge Ma
    So the transmission in my girls Delsol Si is shitting out on me, I have a DX trans I was going to swap in for the meen time when I would be rebuilding it.
    any suggestions on what to look for first the gear or teh syncro sleves? Ive rebuilt a few tans before, but that wat to either just take them appart to learn or drop an LSD into it, never had to repair one before, any suggestions on parts would be welcome aswel. were building hger motor for 300+ hp so the trans needs to be stout, im thinking cryo treaded syncro's
  2. StandBackImApro
    StandBackImApro Welding/Fabrication
    Brick, NEW JERSEY
    those cryo treated synchros are a waste of money... like seriously
    get the carbon coated synchros, there the shit
    By the way.. i know a kid here has a white ep3 just like yours and his girlfriends got a sol to.. haha
    1 person likes this.
  3. ep3moschini
    Northbridge Ma
    rofl. .. where can I get the carbon sync's from?
  4. ep3moschini
    Northbridge Ma
    dose any company offer aftermarket support for the D-series transmission? :confused:
  5. StandBackImApro
    Brick, NEW JERSEY
    What kind of support?
    And Gearspeedinc.com has the carbon synchros, go to products then scroll down
    Ill tell u right now, those carbon syncs make shifting sooooo smooth
  6. ep3moschini
    Northbridge Ma
    where can I order them from, like I want to do a full rebuild, it currently grinds 3rd gear. . . and makes an unhappy noise in neutral, im assuming one of the berrings is toste
  7. StandBackImApro
    Brick, NEW JERSEY
    Go to gearspeedinc.com then products and at the top in the box where the LSD is itll have a number u need to call
  8. turbo sol
    turbo sol I need some ligaments!!!
    laurel, montucky (ten minutes out of billings)
    not too many...i have the same problems with my sol... too much power:D
    so we have to just keep an extra tranny around so incase it blows we have a replacement. that and we are having custom fab work done on it. the fifth gear under full throttle at 100mph shredded like it was made of paper. so we had a machine shop in cali build us up a strengthened gear setup. but with too much power you can expect some breakage. with 300 ponies to the ground you have to treat things nicely or they will shit out on you.
  9. ep3moschini
    Northbridge Ma
    That sucks, Ive been looking for carbon coated gears or cryo treated gears. . . cant seem to find a price anywhere I know they make them tho, im going to call gearspeedinc.com and see what they can do
  10. turbo sol
    totally...go for it. if you come up with anything good let me know... i'm still looking for parts.
  11. ep3moschini
    Northbridge Ma
    can do
  12. turbo sol
    thanks.
    props to you and an upped rep for the help.
