Transmission fluid
Discussion in 'General Tech and Maintenance' started by slayer1927, May 16, 2011.
  1. slayer1927
    slayer1927 New Member
    1989 honda civic . 5 speed manual I have looked for a place to put tranmission fluid but I can't find a place on top on sides or bottom the only place I find is a sensor on top I am not sure if I shoud put it there or not.
    Also what kind of oil should I use?
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    There's a fill hole(14 or 17mm bolt) that's about the same height as the axle. You can fill through the reverse sensor but make sure the fill hole is open; the correct way to fill it is to fill until fluid overflows from the fill hole(car should be on level surface).
    Any works: GM/Pennzoil Syncromesh, Honda MTF, Torco MTF/RTF, Amsoil Synchromesch, 10w30, etc.
    Many people will just outright suggest Honda MTF but their formulas have changed, and unfortunately I'm not a fan(the latest formula seems closer to ATF; and biased more towards their newer transmissions). If anything, maybe a mix of Honda MTF and 10w30 would be good or best. I'd also avoid Royal Purple Syncromesh; it's pretty watery, like ATF, and doesn't work well when cold.
    I'd suggest GM/Pennzoil Synchromesh+friction modifier or if you're willing to spend a little more, Torco MTF.
  3. slayer1927
    Ok sounds good. Thanx
  4. serrilion
    serrilion In my own little world! VIP
    Vermont
    another good one i have dound is regular Valvoline 10w30... works well if u have a daily driver. I've had it in my civic for 140,123 miles now and it has given me no problems up here in cold butt vermont
  5. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    I am a FIRM believer in Honda MTF. Both old and new formula.
    I didn't have good results with Synchromesh and I had ok results with Exxon 10-30 motor oil.
    Tons of people have had good experience with Synchromesh, as Kevin suggested, but in my case, it was a bust.
