TRANSMISSION MISTAKEN!
Arrogant_
Member
I don't know. I thought I bought a GSR tranny. However, when my speed needle reaches 60MPH my RMP needle is at 3 1/2.
Should GSR's be at 3k on 60MPH?
Need help identify this tranny.
Thanks in advance.
what kind of tranny is it? Is the sticker still on there?
you can see the header at the top...thats where the sticker is.
Mine is an M2A4 (H22 non LSD)
Originally posted by 92civicb18b1@Sep 1 2005, 09:08 AM
in what gear?
If it's 5th, it most likely an LS.
[post=548244]Quoted post[/post]​
It's not a LS tranny. I know it's not.
On 5th gear.
On LS tranny, when in 5th gear and the speed needle is at 60MPH the RMP is at 2/12.
I used to own an LS.
Thanks though
Thanks in advance.
[post=548243]Quoted post[/post]​
Definitely not the LS, the LS tranny wouldn't have a higher highway RPM than the GSR tranny, its got a much longer 5th gear
Originally posted by wanderinman+Sep 2 2005, 11:02 AM-->
Arrogant_
Thanks in advance.
[post=548801]Quoted post[/post]​
What is IT?
GSR, LS, or SI?
There aren't a whole hellovalotta options...
And I thought you just said it's definitely not an LS?
[post=549079]Quoted post[/post]​
Dude its either a gsr or a b16. If its a b16 then i would be happy. Shorter gearing which is beater imo.
Originally posted by scottp11@Sep 3 2005, 04:52 PM
Is the sticker still there on your tranny?
[post=549251]Quoted post[/post]​
Has S80 stamped on the sidewall of the tranny.
I'm assuming it's an SI tranny.
Rollin' @60mph and on 3 1/2 RPM.... let know, or help me out peeple
what size rims and tires are you running? that has to do with speed also.
If you are running a stock tire diameter:
S80 JDM ITR 3500 RPMs = 65mph in 5th gear.
YS1 3500rpms=63.42MPH in 5th.
LS trans you would be kicking 77-80mph.
So yeah, we need your exact tire size because nothing calculates correctly.
Originally posted by 93vicb16a2@Sep 5 2005, 03:53 PM
i am running a 205/40/17
[post=549819]Quoted post[/post]​
Still, nothing calculates.. You need to re-check your RPMs at 60mph. Make sure you aren't doing something like 65...
Your trans/tire size doesn't match up with any stock honda transmissions.. So either you are reading something wrong, or your final drive has been switched with some other trans.
Originally posted by 93vicb16a2@Sep 5 2005, 01:22 PM
i have a b16 si tranny and mine is at 4000 at 70mph
[post=549807]Quoted post[/post]​
The rpm and mph is almost similar to mine.
Sorry guys, it has S4 stamped on the sidewall. Sorry for the confusion.
And I'm rollin' on 15s.
Thanks in advance.
"TRANSMISSION MISTAKEN!!!"
Best.
Title.
Ever.
Originally posted by confusatron+Sep 7 2005, 12:47 AM-->
Arrogant_
Thanks in advance.
Best.
Title.
Ever.
[post=550522]Quoted post[/post]​
Somehow I doubt that. Fucking n00bs.
