Transmission/Motor swap question
Discussion in 'Integra' started by oltrout31, Jun 19, 2008.
  1. oltrout31
    oltrout31 New Member
    Will a transmission from a 93 integra work on a 95? If not will the motor from the 93 fit into and work in the 95?
  2. BseriesBeast
    BseriesBeast New Member
    Boston, MA
    :gives:
    Browse the f**king forums before you ask stupid questions.. (everyone was thinking it so I said it) ^_^
  3. BrutalB83
    Rochester Hills, MI
    The motor yes, the transmission no. It will physically bolt up but the 90-93 uses cable actuation and the 94-01 chassis is set up for hydraulic clutch actuation, so you'll either need a hydraulic transmission or a conversion kit...
  4. lukekenwood
    lukekenwood New Member
    are u interested in selling ur integra and useing the money to start over?
  5. crazylady
    crazylady New Member
    yo i would like to know what front wheel drirve transmission would fit the f20c engine?
    Car building project !
  6. crazylady
    it must have lsd to go with the transmission
  7. BrutalB83
    Rochester Hills, MI
    First of all, start your own thread if you have a question, don't jack somebody else's.
    As for your question, there is no FWD transmission that will bolt up to that motor. If you had bothered to research this at all, you would know that...
  8. civic02
    civic02 New Member
    Fuck you and die. We don't need asses like you
  9. salvadorrivas13
    salvadorrivas13 New Member
    San Jose CA
    lets not start any drama. on this thread eather come on guys......^_^
  10. efhondakid
    Akron-Canton, Ohio
    Aint that the pot calling the kettle black.
  11. xiongv704
    xiongv704 New Member
    nc
    The 93 integra transmission will bolt up and everything but you will not be able to shift without the cable to hydro conversion kit.
    Hasport Billet Mounts
