transmission oil change
Discussion in 'General Tech and Maintenance' started by thiebert, Aug 25, 2005.
  1. thiebert
    thiebert Senior Member
    Vancouver
    any suggestions for what is the best oil to use in my tranny. 90 zc civic.
    and any tricks to prevent me from suicide when attempting to refill tranny
  2. formby
    formby learning in progress
    oem oil....3 quarts....
  3. reckedracing
    reckedracing TTIWWOP VIP
    NY
    refill tranny with a long funnel and a 90 degree elbow, or use a suction gun...
    or a funnel with a piece of hosing...
  4. 97CTR
    97CTR Senior Member
    Honda MTF around 6.50 a quart from dealer.
  5. smooth_criminal
    smooth_criminal Senior Member
  6. B16CRX
    B16CRX Senior Member
    Greenville, SC
    Pennzoil synchromesh. 2.5 qts. This is easier than an oil change and will take less than 10 minutes. No suicide required ;)
  7. morgan_spydergt
    morgan_spydergt New Member
    Q: where do you refill ?
    91 civic hb d15b2 ,factory as of now , question is though , when i am under the car i see one screw with a square for my ratchet , obviously to drain the oil .. then a lil ways up is a bolt , is that truly the refill spot ? not sure so i haven't attempted this yet ...
    any help would be awesome ,
    thanx
  8. eg6sir
    holy back from the dead to threadjack batman
  9. Periculum
    Periculum Senior Member
    Martinez, GA
    Yes the higher one is the refill point. I would suggest finding a way to keep your car level when filling or close to level. Just like they have said, it should take 3.5q. You can use 5w-30 no problem or go with the honda 'genuine' transsmission oil.
  10. morgan_spydergt
    sorry gonna be a cheap ass cause when i pull that motor that trannys going too , its a 4 speed stick and i hate 4 speed .. it pisses me off .. driving on the highway , shifting into 4 , just feels so empty ... like i was ripped of by not getting a 5th gear ....
    10w-30 already in the back of the car , just needed that info afore i went and did something stupid ...
    thanx
