I have a 95 Integra LS, and I can't put it into gear. Everything is stock on the car (clutch is hydro).
It all of a sudden fail to go into gear during a drive. I had to stay in first gear and slowly roll home. I checked the slave cylinder and it seems to be working fine (it's got plenty of pressure at the plunger). The clutch have pressure when depress. No leaks found anywhere along the line.
When the car is not running, it will go into any gear. When it's started, it won't go in any gear. The clutch is still good, because when I put in 1st gear and start the car, it jerks. Anyone experience this?
Before I pull the tranny, I just wanted to get some advice/suggestions.
Thanks in advance.
Thanks in advance.
