Transmission seal issue [b16 cable]
Discussion in 'General Tech and Maintenance' started by formby, Jul 23, 2007.
  1. formby
    formby learning in progress
    i have a b16 non lsd cable transmission and my rear seal is leaking. however i dont know which seal to buy at auto zone?
    do i get the 90-93 integra cable seals or the 99-00 si hydro seals?
    i need to buy all this stuff before i change the gator axles i'm buying off will.
  2. formby
    bump
  3. formby
  4. jlicrx
    jlicrx Senior Member
    Colorado Springs
    if you have axle seals leaking, the passenger side ares all the same 90-00 Integra - the driver's side depends on which intermediate shaft you have - 90-93 intermediate shafts have female end where the axle goes in and use 90-93 Integra seal at the transmission - 94 and up intermediate shafts have a male end where the axle goes to and use the 94 and up Integra seal in the transmission
  5. formby
    thank you soooo much.
    so it should not matter if ita a b16 or b18?
    the cases are the same?
  6. jlicrx
    Colorado Springs
    yes, it won't matter
