Transmission
Discussion in 'Forced Induction' started by Pootie, Feb 19, 2003.
  1. Pootie
    Pootie Junior Member
    can i get peeps opinions on what hydro transmission they recommend for turbo applications on b series engines....i heard ls is the best for turbo setups cuz of the long gears
  2. mwasnp
    mwasnp Senior Member
    Hopkins, MN
    I hear LS thats what I am going to use with a quaiffe differential. Some swear by gsr trannies, if you have the $ Iw oudl try both, if not use ls.
  3. pissedoffsol
  4. Pootie
    Would someone be able to explain y gsr is better than ls in terms of boost or vice versa?
  5. pissedoffsol
    gsr keeps you in the power band better.
    read in our article section about mph per gear. on an ls, you will be doing 80 mph in 2nd gear, 130 in 3rd on an 8000 rpm motor - thats just too long
  6. Bri94lst
    Bri94lst Senior Member
    Im also going with Gsr. My Ls tranny will be for sale soon
  7. Pootie
    i also have the jdm type-r tranny w/ the 4.785 final drive....will that be even better than the gsr since it is even closer?...tia
  8. pissedoffsol
    thats a little too close. you will have a lot of power and simply backe 1st, 2nd and 3rd gears with out moving 10 feet =)
    gsr is the best compromise
  9. civicSiR1
    civicSiR1 Senior Member
    Gsr....enough said......
  10. cws13
    cws13 Senior Member
    Athens,GA
    It depends on the turbo and what you are going to do with the car. It's a tough question.
  11. Pootie
    thanx for all ur help guys....i'm jus so confused as to what tranny to go with.....i don't wanna make a mistake choosing a tranny....i have a friend who swears the ls tranny was the best for him...he said it knocked almost half a second off his quarter when he switched from gsr to ls......damn, decisions, decisions!!!!!!1
  12. pissedoffsol
    the gsr is the tranny for the 1/4. no if's about it.
    if yo are a highway racer, the LS is for you.
