Transmission
Discussion in 'Integra' started by sleeper88, Jan 19, 2007.
  1. sleeper88
    sleeper88 My mom thinks i'm cool
    Parkesburg, pa
    I have a ys1. i took it apart to put a phantom grip in it. THe output shaft does not spin. It didn't spin when i got it. I'm about to put it in my car. My question is should the trans output shaft be spinning freely or not?
  2. welfare
    welfare Ancient Member
    New York
    you mean input shaft?? there is no output shaft. . .
    if you are talking about the big shaft that is in the middle of the bellhousing that your clutch is attached to, then yes, it should spin, even if the trans is in gear it should move.
  3. dappa1
    dappa1 New Member
    Queens, NY
    so what happens if it dosnt spin, :confused:
  4. welfare
    New York
    then something is jammed on the inside the tranny, or the trans was improperly re-assembled.
  5. dappa1
    dappa1 New Member
    Queens, NY
    i see, i had a problem like this before. but i never got a chance to install the tranny do i didnt kno if it where bad or not :confused:
  6. welfare
    New York
    it shouldn't cost much to take it to a tranny shop or at least someone who is very mechanically inclined to manual transmissions in order to find out what the problem is.
