trouble codes jdm obd1 b16a into eg
CivicKid04
I got trouble codes 20 Eld unit and 22 vtec switch
I don't have an eld unit (or wiring) was wondering if there is a quick or alternative solution rather than getting one.
On my vtec unit were the pressure switch would normally go it is capped/blocked off from factory, do I drill it out and tap it and get a switch
whats up with that anyway thanks
what ecu are you running?
ELD is in the distributor.
post a pic of the pressure switch filled in. i've never seen that.
the only reasoning i can thinkg of is that the previous owner had a JDM p73 ITR ecu on it, which doesn't use a perssure switch
