trouble starting the teg
Discussion in 'General Tech and Maintenance' started by eg6sir, Nov 22, 2010.
  1. eg6sir
    Last night i tried to start the teg and it just cranked over like it was out of gas... i tried pumping the gas and it got it started... any ideas? Need to fix it asap
  2. hondafreak513
    hondafreak513 New Member
    O hi O
    usually when that happens it has lost compression. do a compression check on it.
  3. E_SolSi
    fuel pump / filter??
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    got to start with the basic check for fuel and spark
  5. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    my iacv sticks a lil when its cold out and does the same thing, if i give it half throttle and crank it its fine. btw i have a gsr iacv. A buddy wit a gsr has the same issue.
  6. hondafreak513
    O hi O
    i have never had to replace a fuel pump and this guy i know has worked on honda for over 30 years has never had to replace a fuel pump.
    [QUOTE ]got to start with the basic check for fuel and spark
    he says it starts just gotta pump the gas that means its getting spark and fuel.
  7. eg6sir
    Ill check out the iacv... could be the fuel filter though, last time I changed it was 4-5 years ago... plus the woman always drives on empty
  8. 95b16coupe
    95b16coupe New Member
    ct
    Is there gas in it? Lol
  9. eg6sir
    Come on... u kidding me? Of course there is gas.. like half tank
    But went and tried to start this morning and it fired right up
  10. 95b16coupe
    ct
    hey, i'm not the one who said she drives it on empty all the time. lol
  11. Supersonicbug
    Supersonicbug New Member
    Try checking your distributor as it can be intermittent result from wear and tear and high temperature may cause it to fail temporary. Delivery of fuel into engine and it could be fuel filter or worse fuel pump.
  12. jdmLife
    jdmLife I KILL V8s
    Tucson AZ
    check to make sure ur fuel pump is priming properly, my turbod b20 vtec eg had a warlbro 255 fuel pump and it had the same problems turn ur key on untill the cel light turns off then turn it over and if you still have to pump it then have it checked
  13. eg6sir
    i went out the next day and she fired right up.. been fine since.. she was just being moody that afternoon i guess
  14. Briansol
    does it have a carb?
  15. eg6sir
    yep.. its a carb'd 01 GSR .. :ph34r:
  16. Briansol
    well, why are you gas pumping a fuel injected car? lol
  17. hondafreak513
    O hi O
    maybe he had the choke on......
  18. Briansol
    did you kick it down? :)
  19. hondafreak513
    O hi O
    poor some gas in it to start it next time
  20. eg6sir
    I dunno.. lol.. but it started when I did that
