today i lowered my car... most of the way. the front went down just fine but when i was taking off the rear stut assemble i broke the bolt that hold the strut to the swing arm, does anybody know were i can get another one of those or if i cau just use any bolt that is the same size, the one that broke has ridges in it, im not sure if they are necessary. thanks, on and while im confused, i put on a body kit, but the front needs some tweaking, is there any special method for fiberglass? or should i just use a filler and fill in the gap inbetween the bumper and the body between the headlights and the weel well... thansk for any help andrew.
ok just use any grade 5 or 8 bolt (do not just use a shity no rated bolt spend the extra 1$) and as nfor the body kit post some pics in the body form
