Truth about block guards
Discussion in 'Engine Building' started by disableddan, Mar 15, 2009.
  1. disableddan
    disableddan Crazy Insane
    Edmonton Canada, Eh?
    Hello,
    Just wondering what the real deal is with block guards. I remember reading that they can do more harm than good... What makes for a good block guard?
  2. Briansol
    you're better off without it.
    open or sleeved.
  3. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    they restrict coolant flow
    your better off investing into sleeves
    maybe pinning the block if your going all out drag but that's another discussion in itself, I haven't done it, but have heard about it.
  4. disableddan
    So how does one remove the stock sleeve from the block and replace it? I found one site with a write up on darton sleeves and they just machined the orignal block right out and put the sleeves in (sounds expensive :D)
    Is there any way to make a blockguard not mess up your cooling?
    I saw this write up on block pinning on HMT, seems like it could work and isn't very expensive or difficult...
    Thanks!
  5. Z6CRX
    Pittsburgh, PA
  6. Magana559
    Magana559 The Warden
    fresno Ca
    well I dont know people, I had my bottom end built by Stewart Racing Engines and they installed a block gaurd. If it was a bad thing why would they put one in?
  7. MthaFuknGreen
    Lodi, CA
    you can get an h22 sleeved for like 600.. so ive heard.
    and is there not supposed to be sound in that video?
  8. disableddan
    Yeah sucks it had no sound.
    I'm just wondering if making the coolant passage holes in the block guard larger would help with any cooling issues and make the blockguard more dependable?
    Spending that kind of money to sleeve a block is way out of my budget, for now :D
  9. MthaFuknGreen
    Lodi, CA
    it tripped me out cuz that video didnt have sound and the video i played right after it from another thread didnt have sound and earlier this guy was telling me about how he has no sound for videos online on his computer.. i was like wtf? this fool told me about his problem now i have it?
  10. disableddan
    Well shit man don't give my computer the no sound bug!!!
  11. Briansol
    sleeving needs to be done at a machine shop (odds are, you don't have the right tools... press, etc)
    usually runs about 800-1000 + new pistons/rings.
  12. Z6CRX
    Pittsburgh, PA
    sorry about that. forgot to add they took the audio out for some copyright reason
  13. RoboRex2005
    RoboRex2005 New Member
    Cleveland, Ohio
    Block guards arnt really worth it. Its a cheap way to reinforce your block to make sure your sleeve dont float at high rpm, and should be honed out after install.
    Another cheap way to do it is a block fill. bout $80. Coolant jacket gets filled with a type of aluminium, then you can drill out the water passages.
  14. Z6CRX
    Pittsburgh, PA
    that has a good change of producing hot spots and potential warping over time.
  15. disableddan
    So pinning is probably the cheapest reliable method of reinforcing the block...
  16. Z6CRX
    Pittsburgh, PA
    probably but overall its usually not worth it and a good idea to check the sleeves are straight afterward. As in boring the sleeves.
    You run into the same issue with metal expanding at different rates if you use a dissimilar metal.
    Unless you are going all out drag and pushing out ridiculously high numbers out of the block I wouldn't waste too much time with it.
  17. disableddan
    Yeah not really planning anything too insane, maybe some boost at some point but I still gotta find out what's wrong with it :p
    Thanks
  18. Z6CRX
    Pittsburgh, PA
    as b said. i would not even bother with it.
    most stock sleeves on hondas hold up really well anyway. its just the pistons and rods that go out under high power.
  19. disableddan
    Cool, have you guys ever heard of using B18 rods in a D15 and getting the ends machined to fit? Supposedly a junk yard fix for beefier rods...
  20. Z6CRX
    Pittsburgh, PA
    D16's maybe, but not d15's.
    you have to machine the wrist pin. but anything further than that I don't know.
