Trying to get my Catch Can hoses right. (made some diagrams)
Discussion in 'General Tech and Maintenance' started by Andrew, Nov 13, 2006.
  1. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    Well, after reading Ian's build, he got my thinkin about my need for a catch can on my motor when it comes in(hopefully they'll be done this week!!).
    Heres some quick diagrams I threw together. This is similar to Ian's, but I added a Tee fitting on the black box and left nipple.
    Will this work? I think this is what most people do...
    Or should I do it similar to Ian's build, buy buying the Prelude nipples and stuff? :
    Heres some I found for turbo motors...
    Thx fellas.
    -Andrew
  2. Andrew
    Tallahassee, FL
    Hate to bump an old thread, but I'm still needing some help.
    Do I need to setup a vacuum on the catch can?
    or can both lines just run straight into the can, like my first drawing?
  3. Andrew
    Tallahassee, FL
    Bump. Edited eveything. need some thoughts!
  4. Andrew
    Tallahassee, FL
  5. Andrew
    Tallahassee, FL
    I'm trying to find out where the fittings are for the back of the block(if I need to use them?)
    Honda Automotive Parts
    Any help would be much appreciated!
  6. Andrew
    Tallahassee, FL
  7. cypher
    cypher Faster then you!
    Houston, Tx
    on mine i just ran 2 #10an fitings from the front of the valve cover strait to the can
  8. Andrew
    Tallahassee, FL
    Yeah, but D series only have 1 valve cover breather. B's have 2.
    I plan to eventually do an AN setup, but I need something soon
  9. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    B's only have one valve cover breather...what Cypher did is drill two holes in the front of his valve cover and put AN nipples in them.
    Here's a great writeup oh the catchcan/breather/whatever thing that I used...it's for a B-series, but everything is more or less the same. Honda Acura Forum - Tech Performance Forums : Civic, Integra, Accord - DIY Oil Catch Can -- How to
  10. pissedoffsol
    yeah, tbone did the drill holes in the valve cover too....
  11. phunky.buddha
    Dallas / Fort Worth, TX
    My engine was set up like the first diagram. For a turbo setup, I would want to make sure that the oil drain has a straight shot DOWN to the catch can.
