tuning a b20 with a safc
Discussion in 'Engine Building' started by 97hatch, Jul 12, 2005.
  1. 97hatch
    97hatch ?
    Anderson IN
    well as it says here is my setup. im runing a b20b and a ls ecu i also have a set of accel 290s my only main cuestion is what type of af/r should i be looking to go for i know that i want it to be about 11.5 with nitrous but what about just regular driving i have a zetronics wideband and t does do data loging rpm/load/afr any help would be great
    thanks
  2. phunky.buddha
    Dallas / Fort Worth, TX
    For regular driving you can stay in the low 15s for ratio- up above 50% throttle and in the upper revs is where you need to start looking at getting your fueling into the rich area.
  3. pissedoffsol
    idel is fine in the 16's... but i wouldn't aim for the 15's even at part throttle... but what do i know... i've only tuned 1 car. lol
  4. 97hatch
    97hatch ?
    Anderson IN
    lol so what numbers should i be looking for at 50%+
  5. phunky.buddha
    Slowly ramp your a/f ratio numbers down from stoichiometric through to mid 12s at full throttle. Make it a smooth transition. After you're done tuning without nitrous, turn on the juice and make sure you're able to run just below 12:1.
  6. brian11to1
    brian11to1 Senior Member
    ok, to tune with an safc do you need a wideband, I understand it's going to be a more acurate tune, but do you need a wideband. it is mandatory.
    one more question, could you say... borrow someones wideband, tune with it then uninstall it?
  7. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    For a good tune, yes, a wideband is mandatory, regardless of whether you have a SAFC or standalone.
    And yes you can borrow someone's wide band, tune, then uninstall. I'd just go to the dyno though. I assume dyno's hookup a wideband when you pay for the dyno time. I have a wideband though, so I have the tools to effectively tune it without the dyno. But dyno is THE best way to tune.
  8. brian11to1
    Interested in a road trip to Avondale, AZ? Food, Lodge... all that shit... help me out...
  9. sohcslammer
    sohcslammer Senior Member
    Bay Area
    MikeB - do you tune your own shit? If not, where do you go around here??? I'm always looking for good tuners. You live up by Sac right?
  10. MikeBergy
    Central Coast, CALI
    I live in San Luis Obispo. I am almost done with my build. 11.5:1 compression, pnp'd LS head, obd0. I'm going to be tuning with a socketed pm6 w/datalogging port, and an Innovate LM-1 WB, RTP with ostrich, tuning with Turboedit. I am just waiting for my pm6 to come back to me, it was throwing a solid CEL when I plugged it in, so I sent it back to be replaced. I'll let you know how my tuning goes. If it goes well, I might consider doing it for some others.
  11. MikeBergy
    Central Coast, CALI
    Only if you show me a good time... :p
    But seriously, if I get my car together soon, I'll consider it. Got the whole rest of summer.
  12. brian11to1
