turbine wheel not spinning
Discussion in 'Forced Induction' started by Egturbohatch, Oct 9, 2009.
  1. Egturbohatch
    Egturbohatch New Member
    hey i just install a new t3/t4 turbo and wen i start the car, i chekked if the wheel is spinning on the intake side ( dont really kno wat it called) and it's not moving at all like it's not working but wen i rev the motor it spins. the wheel does spin wen i spin it wit my finger( wit the car off) so is it a bad turbo or some turbos are like that, please let me kno....it is a new turbo ( cheap ones for now )
  2. EP3Hatch1987
    EP3Hatch1987 Meeeeooowww!!!!!
    so it spins when you rev the car?
  3. Briansol
    does it make boost? take it for a spin around the block.
  4. klyph
    klyph Dismember VIP
    North Pole, AK
    You did plumb the oil lines right?
  5. Egturbohatch
    yea it does boost ( pretty good too)........it does spin wen i rev the engine..........and wat u ( klyph ) mean plumb the oil line.......everything is hooked up.
    the feed line and the return line.............so wat u guys think... it still boost up and it does spin wen i rev it but just dont spin wen at idle............it spin freely wen car is off and i spin it with my finger....let me kno guys..............would this have anything to do wit the blue smoke i got?. note, car already blow blue smoke before i installed this turbo
  6. Egturbohatch
    its a ebay turbo ( for now until tax time baby!)............lol
  7. 97hatch
    97hatch ?
    Anderson IN
    its probaly just a bit large on the hot side and wont spin at idle
  8. Briansol
    it likely needs engine load to do anything. not uncommon.
  9. Egturbohatch
    so is my turbo ok or not???
  10. TurboRex90
    TurboRex90 Golden EG
    Maryland
    Thats odd. Never really heard of that happening,
    I know mine spins at idle and its an egay t3/t4 as well.
  11. Magana559
    Magana559 The Warden
    fresno Ca
    If its a big turbo it wont spin at idle, Most turbos need a load so they can spool.
    If it builds boost quick then its ok, no big deal nothing to worry about.
    Plus if your running a log manifold your probably losing a lot of flow there.
  12. TurboRex90
    Maryland
    I still dont get it. Im running a log and it still spools at idle for me.
    Im not tryin to thread jack, but im super curious as to why he's having this issue.
  13. hunter4life
    hunter4life Rotary Man
    Canada
    My rex needs a load I'm pretty sure
  14. Egturbohatch
    trust me im confuse too..... i had another ebay turbo before this and that 1 spins at idle. just dont kno why this 1 dont ....but the good thing is that it still spools and working other than at idle. but still i gotta rebuild the motor cuz i think my rings r f**ked blowing blue smoke like crazy mostly wen im accelerating ..
