Turbo B18b1 or B18c5
Discussion in 'Integra' started by chrono404, May 11, 2007.
  1. chrono404
    chrono404 New Member
    I have a 2001 Acura Integra LS. Its all stock at the moment, as I just got it recently. My Question for you all is wither I should Turbo Charge(or Supercharge, Whatever gives more power) my B18b1 and do some headword. Or Get a B18c5.
    The B18c5 Will cost 4500US, But For 4500US I know I can do alot to my B18b1.
    I want whatever will give me the most bang for the buck.
    Thanks for your input.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    turbo the b18b
  3. chrono404
    Damn, that was a fast reply. Thanks for the input. I will see what some other peoples say as well But I am leaning in favor of this option. :)
  4. onesikdb8
    onesikdb8 Member
    AZ
  5. jaykeMURD
    jaykeMURD New Member
    KY
    I totally agree with onesikdb8 and ahhvtec.
    Believe me, spooling a turbo is MUCH more "pleasurable" than VTEC engaging.
  6. bannacrx
    bannacrx New Member
    i agree. ive got a gsr in a 89 crx and dont get me wrong, it runs very quickly. but i just dropped an ls motor into my 92 eg and my plan is to go ls turbo
  7. chrono404
    Thanks for the input Guys. I am going to Turbo Charge my B18b1. I plan on having the head port and polished. Is there anything else I need done to get the most power of it besides installing the Turbo and doing the headwork?
  8. jaykeMURD
    KY
    Don't plan on more than 8-9 psi if you're leaving your bottom-end stock.
    There are PLENTY of articles and discussions about building an LS-Turbo.
  9. boofthese
    boofthese New Member
    boost the LS ive seen some people make MAD power out of ls motors
  10. myah
    myah Neu Impact Performance
    ks
    totally turbo your ls man they can be fast one of my friends had a ls turbo hatch back that ran low 13's on a stock motor
  11. ejclide
    ejclide Swapper for life!
    OH---------IO
    if your budget was 4500, you can make a bulletproof bottom end AND do your headwork, and if you spend wisely, piece together a good turbo kit. otherwise, you're stuck with low boost. If the money's in your pocket, slap the GSR head on there, then boost it.
    boost + vtec = fun
  12. terribbleteg90
    terribbleteg90 New Member
    casa grande az
    boost the ls hell i built a bottom end on my a1 for 2200 that will handle 15 psi and 450 hp i got nippon pistons there bad ass and i put gsr connecting rods for compression i only ran it about ten minutes i think the head is bad so im sellin the block with all that brand new stuff and goin gsr all the way but deff. the ls there bad
