Turbo Choices
Discussion in 'Forced Induction' started by 92stoccord, Dec 10, 2015.
  1. 92stoccord
    92stoccord Big Member VIP
    Salem, Ohio
    Wow it's been a while since I've posted in a tech section.
    I sold my civic hx to a friend who drives weekly from Northeastern Ohio to Detroit weekly. I handed it off at nearly 300,000 miles. It's at around 320,000 now. He just bought a Forester for winter driving/battlewagoning. The civic still runs good other than some tired seals and a bad maf sensor. We've both been mpg nerds for a while and we've been talking about taking the motor out of the civic and rebuilding it, along with modifying it around efficiency. I remember reading a while back about a guy who built an EG that ran 55mpg with air and power steering. He had a turbo setup that ran as close to 0psi as he could get. While we have the motor out and disposable incomes, we wanted to try to replicate or beat that. My target is 60mpg. He's a little more ambitious. So my question:
    What would be the best size turbo for basically eliminating the need for the engine to generate vacuum? I'm leaning toward a new turbo oem to a factory dsm turbo. Since we're not worried about power figures I don't want to go overboard and buy a train turbo, but I also don't want to destroy a motorcycle sized turbo, and most of those that I've seen are 3 bolt flanged. Any thoughts?
  2. Briansol
    I don't understand running 0 psi... why turn the thing and make heat for 0 change in what you can suck in through the atmosphere?
  3. 92stoccord
    Salem, Ohio
    0psi uses the turbo to eliminate the need for the engine to also act as an air pump and generate vacuum. I believe it's the operating principle in the "eco" of ford's eco boost.
  4. Briansol
    I was under the impression taking away 2 cyls but maintaiing power when needed was their idea. I guess there's some value to be had by not sucking in air, but we're talking a few milibars here of difference between WOT n/a and 0 psi
  5. 92stoccord
    Salem, Ohio
