What is the most common way to run the Water lines to the turbo? SHould i tap into the existing cooling sytem for the motor; or have a dedicated loop just for the turbo? Please post up any info regarding Fittings, and places to tap into, or places to buy things for a dedicated water loop(ie Radiator, fan, pump, etc).
Most setups I have seen have been ran from the throttle body outlet nipple to coolant supply to turbo coolant return to intake manifold inlet nipple (where throttle body outlet was located) with 3/8 rubber hose Or you could "T" it off from the heater core, some suggest using the lower hose to avoid air pockets. Hope this helps maybe someone can give you a second opinion because I am not a FI guy.
