Turbo D16Y8
Discussion in 'ECU's, Electronics, and Tuning' started by Xaero3953, Nov 17, 2005.
  1. Xaero3953
    Xaero3953 Senior Member
    Ft. Worth, TX
    So, I've made a decision that many on this site would not agree with. I've decided to forgo the h22 swap, and just stick with turbo-ing the d16y8.
    That's right, I know have an h22a4 sitting on a motor stand, and hasport ekh1 mounts that are useless.
    However, this is the ECU section, so my question is this. is the OBD1 p28 the best ECU to go with? on D-series.org, they say that it doesn't have/support the knock sensor or the crank positioning senser. One guy recommended the p30 that would support the knock sensor, but not the cps.
    If not, what's teh best to use?
  2. reckedracing
    reckedracing TTIWWOP VIP
    NY
    i would go with the P28...
    and no harm in going turbo, the H22 isn't gonna go anywhere...
  3. pissedoffsol
    p28 f0 sh0. as long as you've got a solid tune, there;s no need for a knock sensor.
    sell the h22, have money left over after your turbo setup.
  4. Xaero3953
    Ft. Worth, TX
    Yeah, that's what i've been thinking. There's still a little bit of work to do before i can sell the h22, a couple of bolts are MIA. They seem to agree on d-series that the p28 is best. Now i have a hella lot of research before I can start buying up parts...fun. How safe is it to boost on stock internals? The pistons, rods, and pretty much all internals are brand new. I have two heads, one is on the motor right now, the other is awaiting the fateful day it sees portflow.
  5. reikoshea
    Dallas, TX
    Give reiko a holla when you finish...id rather have 2 H22s to piddle around with [​IMG]
  6. pissedoffsol
    you can safely and reliably get 200-225 out of a stock-block d with crome/comparable tuning solution
  7. Xaero3953
    Ft. Worth, TX
    Will do, [​IMG]
  8. phunky.buddha
    Dallas / Fort Worth, TX
    :werd:
    Which is more powerful and lighter than your H22 swap would have been.
