turbo for 95 ex
Discussion in 'Civic and del Sol - EG and EK' started by 90htchbck, Aug 21, 2007.
  1. 90htchbck
    90htchbck New Member
    whittier
    i have a 95 civic ex with 120k miles and am looking to add some more power, what can i do that will give it a lot more power, i definetly don't wanna spray, i was thinking about a turbo...is the 95 ex motor a good motor for turbo??? don't wanna spend too much money but don't want the cheap shit either, what would i need to add a turbo??? and how much would it cost me???
  2. c97x
    c97x sorry boss, its turbo
    turbo's the only way to go, but i wouldn't trust dseries rods past 220hp unless you built the motor to handle power. the cheapest kit is going to run you at least 1500 but thats like a bare bones kit ( no intercooler, no fuel management, no injectors etc) your probably going to spend like 2500 for everything, unless you build a junkyard kit...
  3. Dasfinc
    Dasfinc New Member
    220hp is still good for a low 13 second pass, if not faster on a good setup. Anything over that can be overkill unless you have slicks on the front in my opinion.
  4. c97x
    i dont think 220hp is givin a low 13 pass maybe a high 13...
  5. Dasfinc
    Dasfinc New Member
    My friend runs 13.3 with a 240hp Colbalt SS which is a good 600-700lbs heavier than the civic, good driver, and a good setup can run good numbers, 500hp won't get you into the 12's even if you cant drive!
  6. dtob
    dtob New Member
    Ya you can get 250 out of it but I personally wouldn't trust the d16 rods past 220whp to be safe. Even a 200whp car is a pretty fast street car. Its no back to the future delorian or anything but pretty quick for a dd. I had a turbo D16Z6 with a 50 trim T3 pushing 10psi and I got dirty first and second gears out of her. I wouldn't think that I had more than 200whp.
  7. CiViC_SOHC
    CiViC_SOHC Senior Member
    I don't have a junkyard setup and i've only spent about 1500 peicing it together, thats including upgraded stuff. You can get a good turbo kit if you piece it together and dos ome research...turbod16.com is a good site for research.
