turbo help
Ky'sCRX
how much boost will a stock b16 handle or should i just change the pistons and rods?
However much boost on your turbo makes 300-350 wheel HP is about the limit for a reliable stock. Although on a lame tiny T3 or T25 you be blowing hot air well before maxing out the compressor which makes the engine very detonation prone (very high IATs).
are there any good kits on ebay? if there is what kind should i get
