shadowracer95
Member
Here is my dilema, the clutch pedal seems to have play for the first 6 inches of travel then at the very bottom you feel it start to work. Its not that the clucth is slipping but that the pedall has the funny feel to it. The car has just had a custom turbo set up done by myself and a friend. My question is would high heat cause the clutch slave cylinder to wear out prematurely? The downpipe for the turbo is 3in. in diameter and is only 1/4" away from the slave cylinder. I'm really looking for educated opinions on the subject and any helpful info would be appreciated.
