turbo lsvtec daily driver?
Discussion in 'Engine Building' started by gunsnbam, Mar 2, 2008.
  1. gunsnbam
    gunsnbam New Member
    I drive about 60-100 miles a day, could i safely drive a turbo lsvtec b16 head?..if i just turned the boost down or something? and it would be easyer to make 250hp turbo then with NA gsr right? THANK YOU guys! you have helped me out a lot! (mostly through reading stickys and old topics)
  2. ef9hatchman
    ef9hatchman New Member
    Dont boost at all-and get a FMU-(fuel management Unit) itll save you a lil bit on gas.
  3. Marky Mark
    Marky Mark New Member
    sure you can.. you shouldnt even have to turn the boost down if it has a good tune... dont use an fmu.. chip an ecu and get that motha tuned... kinda depends on if you run a stock bottom end or built and what psi your running.. but with a really good tune anything is possible
  4. ef9hatchman
    TRUE
    it matters all about what this guy can do money wise. fmus are cheap like 60-100
    chipping and tuning can cost.
  5. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    If your looking for 250-300whp, it can easily be done, daily driven. I DD my 551whp hatch on 22psi. Fuel pump, fp regulator, 550cc injectors, colder plugs, back the timing off slightly and run low boost on pump gas. Have it tuned on crome or the such. You should be fine with this setup on a decently sized turbo. Just stay out of boost if you want to keep some sort of gas mileage.
  6. ef9hatchman
    chrome is bad as shit it likes to stick then die chrome been fucken up lately for me and every1 i know with it If ur lucky u can find a neptune tuner. they shutting most of them down hurry hurry.
  7. LS_VTEC
    NJ
    What are you talking about? You cannot even spell it correctly. It is "Crome", not "Chrome". Secondly, the software isnt the problem. Your tuner is. I've seen many cars tuned on Crome and have not had issues. Please do not give out false information.
  8. gunsnbam
    gunsnbam New Member
    hmm still not sure if i want to get a gsr head and a lil NOS or turbo b16...really startin to tick me off haha but 250 would be kinda hard to make with a gsr head NA?
  9. gunsnbam
    gunsnbam New Member
    and can you turbo and keep AC and power stearin!?
  10. BrutalB83
    Rochester Hills, MI
    You need to just stop posting. Every comment of yours that I've seen lately is barely legible and just plain bad advice. You clearly have no clue what you're talking about most of the time...
  11. gunsnbam
    gunsnbam New Member
    I was asking if it would be hard to make 250hp NA with a gsr head. And would I have to take my AC out for a t3 or t4 turbo? (i got a 94 honda civic ex if it matters)
  12. newb
    newb phresh VIP
    Backwoods Northwest
    You can keep your power steering and a/c with a turbo. Look around at the different manifold options, and youll be able to find sumthin that will work for you.
  13. ef9hatchman
    no AC or P/S gain like 6 hp lol. less stress on the engine. fcken belts :)
  14. gunsnbam
    gunsnbam New Member
    so why could i not just build a gsr head to be turbo? would i just get more HP with the same PSI with a b16 head?...i was wondering if it was because a gsr head would not be worth the money...i get them both the same at my local junk yard.
    (you guys are really helping me out a lot, thank you very much)
  15. ef9hatchman
    GSR butterfly intake manifold not best for turbo might as well build the head-valves-springs-retainers-cams-shafts-
    get a skunk2,blox,etc. mani whatever u can afford and trottle body.might as well if ur building it. GSR stock is closest thing to type R-u can get.
