Turbo on a 97 Lube
Discussion in 'Forced Induction' started by ovcrash, Jul 23, 2003.
  1. ovcrash
    ovcrash Senior Member
    Quebec, Canada
    I'm looking to put a turbo on my 97 lube. But i don't really know what kind and wich size to get. I would like to get a T66 but maybe it's too much, i don't know i would like your advice?
    I'm looking to get around 15psi on daily driven.
    What size turbine should i get? Should i change my head gasket and get a high compression one?
    what else should be changes when putting a turbo, cam gears? pulleys? injectors? fuel rail?
    I'm changing the fuel pump with a high flow one, and changing the fuel filter too, so that's kind of a start.
    Well let me know your advice, and i like crazy setup's...so if a T66 would not be to stupid to put, then let me know! :)
    Thanks :blink:
  2. rudeludenotmeanthough
    rudeludenotmeanthough Senior Member
    Don't you want to lower your comp. for a turbo??
    And you would prolly wanna change your injectors.
  3. ovcrash
    Quebec, Canada
    Well i don't know if i'm right but, high compression less boost? and lower compression more boost? but with high compression i get more torque so more power at start.
    tell me if i'm wrong.
    what size turbo should i use? should i leave the compression like it is?
  4. ovcrash
    Quebec, Canada
    would a T66 be too big?
    because i wanna have like 300WHP for a daily driven car. OK! probably crazy of me...but hey, i can dreams...maybe it will come true!!!
  5. convertedstangbanger
    convertedstangbanger Senior Member
    ATX!
    how much are you willing to spend?
  6. ovcrash
    Quebec, Canada
    I'm willing to spend alot. I really want a good setup, something really bad ass.
  7. pissedoffsol
    t66? oh boy...
    here we go again.
    if you're willing to spend 10 grand, here we go-
    www.full-race.com for your turbo and manifold needs.
    $4000
    $1000
    www.hondata.com for your tuning software, gm 3-bar, and dyno time
    $4000
    get the block sleeved, 9.5:1 forged pistons, rods, etc...
    $1000
    3" exhaust
    injectors
    misc parts
    $500-$1000
    Gauges (boost, oil pressure, egt)
    opps, we already broke 11,000.
    are you sure you want to get into this?
    and please- don't get a t66. you won't make boost on that until 8000 rpms.
    t3/t04s will suit you just fine. FR63 or precision sc61/61 will suit you well into the 600+ hp ranges.
