Turbo On a D series
Discussion in 'Engine Building' started by Jake15, Dec 19, 2006.
  1. Jake15
    Jake15 New Member
    I want to turbo my 95 Civic DX Coupe it is all stock with D15B7. I want to get in the 200 HP range. What do I need to do to the motor to be able to add a Turbo without having to worry about tearing it up. About how much would this cost.
    Thanks,
    Jake
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Buy the Edelbrock kit- that's the easiest/cheapest way to get to a nice turbo setup on your D. You're not going to be able to hit 200hp at the crank (much less the wheels) without some extra tweaking though.
  3. turb2o_vtec
    turb2o_vtec New Member
  4. Jake15
    Jake15 New Member
    I have 2500 to spend and all labor is free. What can i do with that.
  5. donnie
    donnie New Member
    high desert
    wow ive built my kit for less than 1200. and thats with motor.
    hf manifold and ihi turbo ftw
    13.3@100
  6. Jake15
    Jake15 New Member
    donnie what type of set up are you running
  7. donnie
    donnie New Member
    high desert
    d15b vtec- 295
    ihi turbo- 75
    hf manifold + adapter plate - 25
    jrc intercooler - 120
    DYI intercooler piping kit- 75
    DYI dp - 0
    450 injectors + res. box- 45
    chipped p28 tuned on crome- 0
    made my own oil lines and drains. plus all the labor
  8. Jake15
    Jake15 New Member
    what kind of HP you getting out of it and what are you running at the track
  9. donnie
    donnie New Member
    high desert
  10. cheese9988
    cheese9988 Senior Member VIP
    Lowell, MA
    $2500? b18c and a few addons, could probably do that for less than $2500 if your wise with shopping.
  11. Jake15
    Jake15 New Member
    nice, do you have a civic hatch, crx, or coupe
  12. donnie
    donnie New Member
    high desert
  13. Jake15
    Jake15 New Member
    Thats tight did you do anything internal and is this your daily driver.
  14. donnie
    donnie New Member
    high desert
    crower turbo cam
    ported taper bore TB
    thats about it as far as motor
    the car used to be my dd. but it doesnt need to be anymore.
    I used to make a 2 hr drive to the track. race the car. then drive home
  15. donnie
    donnie New Member
    high desert
    Ive been running this setup for over a year.
  16. phunky.buddha
    :werd:
    I'm $75 into my D turbo setup and all I have left to get is piping and injectors.
  17. donnie
    donnie New Member
    high desert
    yeah I hear you. I live in CA too. having a hmt sucks for smogging.
