turbo or all motor?
Discussion in 'Engine Building' started by GSRCRXsi, Dec 26, 2002.
  1. GSRCRXsi
    MD
    ok for those of you who dont know, i have a GSR engine swapped into my 91 CRX Si. what i want to know is what potential is there for this engine? should i turbo it or go all motor and work with what i have? what will i need to get the best out of a turbo setup and/or an all motor setup? (i.e. internals, pistons, rods, cams, etc.) and also ive been looking around and if i go all motor im goin to get an ITR header, but i cant decide which intake manifold to use. its between skunk2 and JG elderbrock (spelling?). which one would be best for each setup. thanks in advance for any help.
  2. B16
    B16 Super Moderator VIP
    yay area, CA
    the JG is huge, would be good for big turbo or some huge cams... otherwise, the skunk2 will do fine, i'm putting on my skunk2 this weekend
  3. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    i saw a GSR that had the victor X manifold on it running a turbo with a shot of nitrous hit 12.69 at stanton over the summer that thing was amazing
  4. pills_PMD
    New Albany, OH
  5. GSRCRXsi
    MD
    ok, thanks, but should i stay all motor or go turbo? pros/cons of each?
  6. pills_PMD
    New Albany, OH
    all motor: expensive as hell... and you will never go as fast as you want to.
    turbo: less expensive.. but expensive nonetheless... i would go turbo if i could.. but the man slaps me down
  7. GSRCRXsi
    MD
    ok so if i go turbo, what do i need to do to the engine?
  8. pills_PMD
    New Albany, OH
    talk to pissedoffsol i am the all motor master. :) lol
  9. pissedoffsol
    and im the vtec + boost hater
    swap your head for an LS, and then we can talk :p
    seriously though-
    #1- that pic HAS TO GO
    holy fucking resoloution batman
    ok, done- now its a link.
    what do you HAVE to do to your motor? nothing
    what SHOULD you do? well, that depends on your goals.
  10. GSRCRXsi
    MD
    why swap the head? why are you against vtec + boost?
  11. GSRCRXsi
    MD
  12. 22crazy
    22crazy Senior Member
    because vtec causes the exhaust valve to overlap and stay open longer, therefore you loose potential power as the turbo forces air into the motor and goes out that valve. Someone correct me if im wrong...because i dont like giving out false information.
  13. B16
    yay area, CA
    somewhat true yes, they have developed turbo specific vtec cams that have virtually no overlap. stock cams would be next to best for a turbo/vtec setup. turbo and vtec can give you huge gains, just takes more tuning
