Turbo parts, tires and tire stuff, and more
civicrydah
Local buyers only please. Located in toronto, canada.
Here are the parts I have for sale:
Tires and related parts:
(1) BRAND NEW 2 x Goodyear Eagle FI GS-D3 tires. 195-50-15. Traction rated at “AAâ€. Still has stickers on them. Link to more info on it: http://www.tirerack.com/tires/tires.jsp?ti...=Eagle+F1+GS-D3 $300 for the pair
(2) 2 x BFGoodrich Comp T/A R1 tires with professionally shaved tread. 185-60-14. Still has lots of life left for the drag strip and/or few lapping/auto-x days left. Really sticky tires. $120 for the pair or $150 with the steelies mounted on them.
(3) Eagle Ultra Grip performance tire. 195-60-14. Less than 50% left $20
(4) 2 x Toyo Proxies FZ-4. 205-45-16. $50 for the pair
(5) A set of 4 Del Sol Rims powder coated gunmetal $250
(6) 2 x black steelies. 4 x 100. 14 inch steelies. Currently have the Comp T/A’s mounted on them $50 for the pair.
(7) 16 x Lug nuts + 4 wheel locks and 1 key. 12 x 1.5 mm $30
Turbo parts:
(8) Cartech Adjustable Fuel Management Unit. Boost dependant. Can adjust fuel pressure in ratios up to 12:1. Amazing capabilities for tuning. Never have to purchase extra discs. Link to more info on it: http://www.cartech.net/fmu2020.htm $160
(9) MSD BTM (boost timing master) Part number: 5462. A must for all the guys who want to turbo a Honda. Link to more info on it: [url=http://www.msdignition.com/]http://www.msdignition.com/ [/url] Type in the part number in the search to see the page. $160
(10) DSM pink top 380cc injectors. Great for homemade turbo setups. There is no difference in running 450 cc injectors because you’re going to have to lean them out with an AFC anyways, just not as much. $60
(11) Busta Manual Boost controller $30
(12) HKS Turbo Timer Type 1. Silver face with blue indigo. All the goodies and options from the Type 0, but you also get 1/4 time, MPH, RPM etc. Acts like a G-tech and turbo timer! Link to more info on it: [url=http://www.hksusa.com/products/?id=845&rsku=]http://www.hksusa.com/products/?id=845&rsku= [/url $175
(13) VDO Blackface Boost gauge. Reads from 30 Vacuum to 25 PSI. $60
(14) Carbon Fiber A-pillar for 1g Talon $20
(15) High temperature stainless steel braided oil lines with Earl’s Competition fittings x 2. Each approx. 5 feet in length. Don’t know the size of the fittings, but you’re welcome to come check them out. $40 for both lines
Honda parts:
(17) D-series DC 4-2-1 ceramic coated header with o2 sensor and wire (it is rusted on). Collector has to be welded on. 2 piece design. Trade for your o2 sensor with wire and $120
(18) One crossed drilled rotor from a 97 Civic Si $20
(19) Integra Shift knob $10
(20) Brand new Fuel tank for civics and Crx’s. Still in box. Best offer
(21) Brand new rotors for 90-93 Integra Best offer
(22) 88-91 Crx cargo cover for rear. Best offer
Misc. parts:
(23) 10†Carpeted plexi-glass box with blown 10†Jenson sub $25
Pictures of everything (except sub box) can be found here: http://www.villagephotos.com/pubbrowse.asp...selected=585449
Sub box and MSD BTM pictures can be found here: http://www.villagephotos.com/pubbrowse.asp...selected=585659
If you are interested in any of the items, you can PM me or post here. But for the quickest response, email me at mistamoe69@hotmail.com
