turbo questions
Discussion in 'Civic and del Sol - EG and EK' started by EP3Hatch1987, Nov 13, 2008.
  1. EP3Hatch1987
    EP3Hatch1987 Meeeeooowww!!!!!
    i got a turbo kit for my single cam but dont know what injectors would be good or what clutch would be best... because im trying to get all the parts necessary so it will runn perfect. so what do you guys think?
  2. austin20110
    austin20110 New Member
    Northern Va
    what kind of turbo is it(size, color lol jk about the color)
    How much hp is it going to be running?
  3. EP3Hatch1987
  4. austin20110
    Northern Va
    Is it going to stay that way or are you going to upgrade to a real turbo?
  5. EP3Hatch1987
    going to upgrade pretty soon but just running this one for now...
  6. austin20110
    Northern Va
    ok so what are you upgrading too.. no point in buying 2 sets of injectors
  7. BrutalB83
    Rochester Hills, MI
    There's also no point in having to tune it twice. Don't do this "well I'm just gonna use this starter turbo for now and then upgrade a little later" crap. Just wait, save your money, and use the parts that you really want the first time. That way you don't have to go back and redo it. It will actually be cheaper in the long run...
  8. austin20110
    Northern Va
    i dont think he knows what tune is
  9. bluemk3
    bluemk3 Supra & Civic-T Owner
    Altoona/ Pittsburgh
    to answer the question you are asking 440cc soudl hold fine for the t25 but you should either stick to the t25 or just wait till you get a t3/t4 garret or sumthing. that turbo will supot you till 325hp or more and they spool quick. it would be your better bet without building your motor
  10. t3t4delsol
    t3t4delsol New Member
    York, Pa
    If your referring that a t25 will support 325 hp your crazy, the are two small and will probley max out around 200 hp on a honda, hell they max at 240on a dsm, they are not good for over 15psi because they will only move air not produce any more power. A t3/t4 50trim is your best bet for a d16, expect full boost around 3500 - 3900 rpm. Also if you looking to save a little bit of green on the injectors, get some dsm 450s and a resistor box.
    Also when you upgrade to the t3/t4 you will need a new exhaust manifold, downpipe, and external wastegate.
    Btw I have a 5 bolt t3/t4 3" stainless steel downpipe with braided flex, that I had on my d series for sale, Pm me if your interested
    As far as clutches go, I got a stage 3 f1 carbon/kevlar disk and the pressure plat to match, I also switched to a 8.5lb flywheel on my y8, 15k miles on it so far and not one issue, btw F1 is a ebay brand and I belive I spent around $250 for everything the stage 3 is rated for 340hp and I think the stage 2 is rated for 260hp
    Hope this helps
  11. EP3Hatch1987
    how much do the t3/t4 usually run for? because i got this t25 for real cheap and i figure its a turbo.. but eventually later on when i get more money im gunna upgrade it to a bigger one..
    so the 440cc injectors will work and a stage 2 or 3 clutch..
  12. EJ2 civic
    EJ2 civic New Member
  13. EJ2 civic
    http: //photos-g.ak.fbcdn.net/photos-ak-snc1/v374/153/18/504858583/n504858583_968142_4358.jpg
  14. EJ2 civic
    <IMG SRC=http://photos-g.ak.fbcdn.net/photos-ak-snc1/v374/153/18/504858583/n504858583_968142_4358.jpg
    IMG>
  15. EJ2 civic
    <IMGSRC=http://photos-g.ak.fbcdn.net/photos-ak-snc1/v374/153/18/504858583/n504858583_968142_4358.jpg
    IMG>
  16. EJ2 civic
    [IMG SRC=http://photos-g.ak.fbcdn.net/photos-ak-snc1/v374/153/18/504858583/n504858583_968142_4358.jpg
    IMG]
  17. EJ2 civic
    <img src=http: //photos-g.ak.fbcdn.net/photos-ak-snc1/v374/153/18/504858583/n504858583_968142_4358.jpg>.
  18. Briansol
    lol
    use IMG and no spaces!
  19. Briansol
    what does this car have to do with your turbo?
  20. austin20110
    Northern Va
    injectors have nothing to do with your clutch
