turbo set up
stedscivic
94 civic ex coupe
JDM b18c
full interior 17 inch rims system
would this set up be good to reach 13 second 1/4 mile
should be somewhere around 250 to reach 13s right?
Turbo: SC-6031E with .63 A/R ratio turbo
Manifold: t3 b-series 4 bolt
Injectors: RC Engineering 550 cc injectors
Fuel Pump: walbro 255lph pump
Intercooler: PWR Intercooler 2078287 20" x 7.8" x 2.87"
still deciding on the following any suggestions would be awesome
wastegate
blow off valve
wideband 02 sensor
Hondata s200 with boost option
3" exhaust
anything else i might have missed
just curious
what would a small shot of nitrous do with this set up?
thanks
that setup will put you well beyond 250 if you want to go there.
honeslty, the limiting factor in your setup is your 17's with no traction. a 205/40/17 tire will just burn the hell off before you go forward. no sidewall flex at all.
get some 15s
:werd: get some new wheels and slicks.
You don't have to keep them on all the time (which wouldn't be a wise choice anyway).
Keep the 17s for the street.
When you go to the track loose the system, at least whatever you can take out..
You can make 300 pretty easily with that setup or to whatever the injectors max out too.
so all this is ok to go beyond my goals (13 sec. 250whp) which is fine with me
what about the rest of the set up? need help on getting the rest of this figured out so i can get started.
wastegate
blow off valve
wideband 02 sensor
Hondata s200 with boost option and tuned by a hondata mechanic
3" exhaust, take to muffler shop and have them go 3" no cat all the way back to what muffler?
notice anything else that i might have missed?
and what would a small shot of nitrous if i would add that to the turbo set up?
delta or tial wastegate
most BOV's are sufficient enough. 300 hp almost all should be fine
PLX m300
fuck hondata, get uberdata
ES oval with Kteller piping
you don't need nitrous, you should be plenty happy with that.
whats the reason for uberdata over hondata?
and the 3" tubing for exhaust, what else do i need flanges, wastegate flange, should i get a 2.5"-3" high flow cat? what size flex pipe?
Uberdata is free, hondata costs a pretty penny, i would agree, b18c turbo, u should go 3".
you can pay the premium for Hondata, but essentially all the systems do the same thing.
I think Kteller sells it with the flanges, if your going to make it yourself. The I would use 5 flanges all together. 1 for the cat, 2 for the midpipe (so they mate), and 2 for the midpipe to muffler pipe (so they mate).
I would go 3" from the turbo back but I'm using 2.5 DP to 3" Flex back down to 2.5" exhaust.
this is what im thinking
reliable, cheap, fast you can only choose 2 (so Im told) and if uberdata is free then its cheap right?
so i have to do away with fast or reliable and i dont want to do that.
i know uberdata is talked highly about by lots of tuners on here, but is it worth it to spend the money and get hondata
i want reliable and fast so i dont mind spending the money if hondata is worth it
why is uberdata free and hondata so expensive? there must be a reason.
im thinking the tial 38wastegate seem right for this set up, but what size bar for the wastgate?
and what size blowoff valve since there are like a million of them?
I have all three.
Cheap (i spent like 1k...ok maybe 1200)
Fast (good enough for me)
Reliable (we'll find out)
Uberdata is not considered cheap IMO. It good to use when you don't have a retarded amount of money to spend and compares to hondata like butter and margarine. Hondata being high in cholestoral yet good (butter), then uberdata being margarine, less cholestoral yet tastes the same. Good analogy, huh?
Originally posted by 92civicb18b1@Apr 23 2005, 01:42 PM
I have all three.
[post=490570]Quoted post[/post]​
very good analogy
38 mm wastegate would be perfect. Depending on what turbo you decide to use a 8-10 psi spring is a good start.
As for the BOV size, most aftermarket ones will be fine. I personally am using a cheap ass one that I got for free with my HKS BOV from my last setup.
almost got everything figured out
BOV:
greddy type s?
or
hks ssqv?
are either one of these a good choice?
BOV:
greddy type s?
or
hks ssqv?
[post=490690]Quoted post[/post]​
again, Tial 50mm.
Tial > *
Originally posted by pissedoffsol+Apr 24 2005, 04:02 AM-->
92civicb18b1
@Apr 22 2005, 10:46 PM
delta
[post=490357]Quoted post[/post]​
no no no no no!! anything but deltagate.
tial > *
[post=490735]Quoted post[/post]​
Whats wrong with Deltagate?
My buddie has it on his 79 toyota and hes running good #'s...Whats the difference between the two?
[post=490518]Quoted post[/post]​
I had hondata.
i won't own it again.
and not even for the cost part of it. sitting there trying to get the unit to connect is such a pain in the ass. it sucks.
i'm going to be running chrome pro on my all motor hatch. chrome is also free. chrome pro isn't, but it has some features i want.
having seen uberdata, and played with it a little bit, it can do eerything that hondata can- for the most part- its just setup a little different, and its not as clean of an interface. but you don't have to deal with that stupid hondata box.
Originally posted by Estorvito+Apr 24 2005, 10:05 AM-->
Originally posted by pissedoffsol@Apr 24 2005, 04:02 AM
92civicb18b1
delta
tial > *
[post=490778]Quoted post[/post]​
deltagates fucking suck.
their diaphrams break all the time, and they are know for boost spikes.
