hammerdgolfer
so, now that i realize im getting more money then i thought i had, its time to start planning on my turbo kit, i hope it will be complete and tuned within 2 months MAX
now what kind of turbo do i need? my motor was built to handle 25psi, now thats larger than a t3/t4 isnt it?
b16a cable swap(origionaly)
JG Engine Dynamics Gen II Block
Eagle Rods
JE 10.5:1 Pistions
Total Seal Rings
Clutch Masters 7.5lb Flywheel
Clutch Masters 6 Pluck Racing clutch
Unorthodox Under drive pully
MSD Sport Compact Ignition System
Spoon Racing thermostat
Spoon B-Series oil pump
New b16 distributor
New Valve seals
New Stainless Steel Valves
what do you think about that motor?
how much psi would be a realistic number if you dont think 25 is?
and what size of a turbo-thats my main question
Eagle Rods
JE 10.5:1 Pistions
Total Seal Rings
New b16 distributor
New Valve seals
