Turbo Sizing
Discussion in 'Forced Induction' started by statiksol, Mar 24, 2003.
  1. statiksol
    statiksol Banned
    okay, so i got this turbo. its a tdo5h-14b. does anyone know how good this thing is and what the specs are on it?
  2. pissedoffsol
    its a small first gen mitsubishi turbo.
  3. statiksol
    statiksol Banned
    how much boost is it capable of and what psi is it most efficient at?
  4. pissedoffsol
    10-14 is probably its top range
    like i said, its small
  5. statiksol
    statiksol Banned
    okay, well i have an ls/vtec in my del sol thats totally built so about 10 psi out of that turbo should do me well.
  6. statiksol
    statiksol Banned
    also i need a downpipe for it. what car did it come off of and where can i get a downpipe?
  7. pissedoffsol
    IMO, its way too small for an ls/vtec.
    i think you would be much happier with a t3 60-1 or a t3/to4e
  8. statiksol
    statiksol Banned
    i don't have the cash for something like that. i got this cheap and it should do just what i want it to hopefully. i would like to know if its a good idea to use it though?
  9. mwasnp
    mwasnp Senior Member
    Hopkins, MN
    It cant hurt. Don't expect to generate much more than 50 additional hp with it @ 10 psi, tune well, I am assuming if you're fully built you most likely have a high cr, and in this case tuning to the hilt is a MUST!
  10. statiksol
    statiksol Banned
    well 90 ls bottom end, gsr main girdle, eagle rods, srp 10.5:1 pistons, str block guard, arp head studs. b16 head, crower 1mm oversised valves, crower dual valve springs, crower titanium retainers, gsr cams (for now), skunk2 intake manifold, type r throttle body, dsm 450cc injectors, holley 255lph fuel pump, aem rail and regulator, str cam gears, and apexi vafc. will it work well with all that?
  11. SolReaver
    SolReaver Senior Member
    :werd:
    t3/60-1 :wub:
  12. statiksol
    statiksol Banned
    where can i get one and how much are they?
  13. pissedoffsol
  14. statiksol
    statiksol Banned
    god damn thats a lot of money for a turbo! are you kidding me? how much hp will that make on my motor?
  15. SolReaver
    a lot of money? nobody said going fast was gonna be cheap...
  16. civicb18
    civicb18 Member
    IOWA
    you could get it to easily make 300 or 400 or 500 with tuning of course
