Turbo Swap
TegraDoc
I have a question, I recently got a 2000 Integra LS, and I have a friend who has a mazda something or other with a snail in it, he is going to give me the snail cause the car is junk for one reason or another, turbo is good, all I need to know is, is it possible to make it fit my vechicle, I know it may take custom fitting, but other than that, can I make it work? Any help would be great, thanx.
Doc
boost
And another probly stupid question, but, if I throw the turbo on, and my motor is otherwise mostly stock, can I lower the boost and up it later when I get better parts for handling larger boost, and if I did do that, I guessing I need a boost controller?
Thanx again
Doc
you sure can the motor you have can handle 7psi no problem and probly up to 12psi but if it was me i wouldnt go over 7psi on a stock motor
