Turbo timer help
Discussion in 'ECU's, Electronics, and Tuning' started by smooth_criminal, Jun 20, 2005.
  1. smooth_criminal
    smooth_criminal Senior Member
    i have an apexi timer that i'm hooking up, got everything done but it's not keeping the car running, the only thing i was iffy on was the ignition wiring. it says to hook up the blue wire to ig1 and the green to ig2, well in my helms they are listed ias igp1 and igp2 do you think thats the same? And can i hook them up at the ECU or do they need to be hooked up at the ign, cyl?
  2. pissedoffsol
    they wire into the ignition. make sure you unplug the battery, or you will get zapped on the white wire. ask me how i know. :ph34r:
    apexi's website has diagrams of what to conect to.
  3. smooth_criminal
    there site sucks ass, they just say IG1 and ig2 doens't give the coloring of the wiring. I'll have to see if i can figure it out.
  4. pissedoffsol
    you have the little lipstick tube size one?
  5. smooth_criminal
    yeah, it says to wire up to ig1 and ig2 but that not listed in my helms.
  6. pissedoffsol
    i'm going to have to double check this when i get home....
  7. smooth_criminal
    if you could that would be sweet, everytthing else is working fine on it but not the timer and that the most important. LEt me know what you find B, is you could just tell what wire is what on the ign cyl that would be good enought. honda has them listed a igp 1 and igp 2
  8. smooth_criminal
    b, you find anything on this?
  9. pissedoffsol
    sorry dude, never made it into the garage yesterday :(
  10. smooth_criminal
    no problem, I'll check into it later and see what i can find.
  11. smooth_criminal
    OK i got it figured out.
    The IG1 and IG2 wires are located on a brown plug thats pluged into the fuse panel onder the dash.
    The plug will be brown and have 2 wires coming off of it.
    Black w/ white
    Yellow = IG2
    Black w/ yellow. = IG1
