ive seen some people use a vacuum/boost manifold, basically a little block thats got multiple ports. u could use the ones that are made to split air compressor lines, you'll find nice anodized ones.it helps clean up ur bay, then just tee the manifold to ur fpr. run ur bov n ur wastegate the the manifold.don't forget to zip tie all ur vac lines.
