Quoted post[/post]]
superchargers on honda's are stupid, especially the centrifical ones like vortech.. its like having a big crappy turbo that runs on a belt and you cant turn up the boost
build your own turbo kit-best bang for the buck. or if your a baller go with full-race^
Reasons why superchargers on hondas are stupid:
1.) Honda's dont make a lot of torque. They rely on variable valve timing and high rmp's to make power. Although it may seem like adding gobbs of torque to your honda would be best, think again -> roots type superchargers run off of your crank pully . . . robbing your car of HP.
-THe parisitic loss from an S/C is not a big deal if your motor is only spinning at 2k or 4k rpms (Detroit Muscle FTW !!11!1!!!y0n3!!!111!) , but our honda's rev till 8.2k . . . thats two times the HP loss s/c'd muscle cars experience.
2.) Honda's are FWD. THe added torque from the s/c will just turn into wheel spin/wheel hop when you try and accelerate off the line.
- on a FWD car the lag from the turbocharger is your friend as you will be able to catch traction off the line . . . then when you have traction, your turbo has spooled up and you will get to accelerate like an animal without wheelspin.
. . . . . so why not get a centerfugal s/c instead? This brings me to point #3
3.) Ever use a "spork" (fork & spoon combo)? A spork is a lousy fork and a lousy spoon at the same time.
A centerfugal s/c is an s/c that tries to imitate a turbo's abilty to progressivly increase HP. Centerfugal s/c's flow air in relation to the vehicle's RPM's . . . while this may seem like a good idea at first, this type of S/C has one
MAJOR shortcoming.
It cant stay "spooled" like a turbo can.
Ok lets say we have a centerfugal s/c that will flow a maximum of 10psi @ 8k rpms. It will progressively
build up to flowing 10psi something like this: RPM: 5k - 6k - 7k - 8k
PSI: 7psi - 8psi - 9psi - 10psi
After you shift gears, your RPM's decrease from 8k to 6k, so your s/c goes back to only flowing 8psi . . . then 9psi, etc.
Now lets say we have a comparable turbocharger set to flow a maximum of 10psi.
Turbos have the abilty to stay spooled, meaning that after you shift gears, your turbo will
not revert to flowing less air like our Centerfugal S/C will. Once the turbo is spooled up, it will flow that 10psi all day long even if you shift gears (some air will escape provided you have a BOV, but it wont stop the turbo from spooling as your motor is still emitting exhuast gasses).
Basically, the turbo will flow 10psi from 6k rpm's untill 8k rpm's when it spools up to maximum boost. When you shift and your RPM's drop to 6k, your turbo will still be flowing 10psi, not 8psi like the s/c would be.
Depending on your turbocharger/engine combonation, you can tune your setup to hit its maximum airflow at whichever RPM is best for the type of driving you do . . . not like a centerfugal s/c that ONLY hits max airflow at redline.
4.) The fastest hondas are TURBO hondas.
my 2cnts
