i read a list of cars that have oem turbos... how exactly do you install these in a crx? are their guides? can you get all the parts you would need off that certain oem car you use to get the turbo?
most... you need a honda manifold... the HF manifold can be welded into a turbo mani with a flange.
else you can buy a reg turbo mani... the rest of the parts aerw custom stuff you can bend pipe, run oil lines, vacuum lines, etc
