Turbocharge d15sohc "DX"???
Titus
can i turbocharge a stock d15sohc non vtec?
i have some kind of compressor that i can stick into the intake to 25psi...?
is it safe?
what is the amount of psi that is safe to this stock engine?
what could went wrong when turbo charging a stock engine like mine?:confused:
beginner needing some help?
yep, you are a beginner needing some help. don't mess with the engine. leave it stock. there are a lot of variables that go into turbo charging and engine. i have no idea what you mean by compressor. and there is no exact psi for a turbo to put on a car. a t3 turbo at 10 psi is wayyyyy different than a t66 turbo at 10 psi.
just keep it like no more than 5 psi and it should be fine
remember that more air in the engine will change the A/F ratios so you'll need to put more fuel into the engine.
better living through tuning.
