Turbo'd B16 CRX
Discussion in 'Forced Induction' started by Citizen_Insane, Nov 28, 2003.
  1. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    About how many horses would a b16 w/ 9:1 CR pistons and a intercooled T3 turbo put out at 14psi? At this boost level would I have to upgrade any of the egine internals? I have done a little research and I figured about 300hp at the crank, is this about right? If I ran 6-8psi in town could I use pump gas? My plan is to build a street crx capable of 11's at the track. Thanks
    P.S. Where should I get my b16?
    -Kai
  2. civic15.8
    civic15.8 Senior Member
    alabama
    get your motor at hmotorsoline.com
  3. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    14 PSI from a t3 on an internally stock B16a is WAY pushing it. If you're using aftermarket 9:1 pistons, you SHOULD be ok, but the rod bolts start to hate life at about 350 hp.
    You should make about 250-275 at the wheels depending on the trim of the turbo. If it's small-ish, 200-225.
    At 14 PSI with correct tuning, pump gas should be fine, even at the track. You might want to back off the timing a little more on 14 PSI, though, just to be on the safe side.
    250 at the wheels in a LIGHT CRX, like 1800 pound, would be capable of some 11's if you can drive, and get the car to hook up.
  4. Citizen_Insane
    Minneapolis
    What trim should i look for to be pushin 275?
  5. Slo86GT
    That's going to take about the largest t3.. a "super 60"
  6. Citizen_Insane
    Minneapolis
    Is there aything cheaper than a super 60 that can get me up to 275-300hp?
  7. pissedoffsol
    most "real" turbos are about the same price dude... expect 800 bucks
  8. Slo86GT
    You can order the big t3's from cheapturbo.com... $550.
    OR, if you get a Thunderbird Turbo Coupe, or Mustang SVO turbo froma junkyard, it's just one step down from the super 60.. It's a big 60 trim turbo.
  9. Citizen_Insane
    Minneapolis
    How much do you think one of those used ones would set me back??
  10. Slo86GT
    Depends on where you get it from... A junkyard will sell you one for $20 - $200 depending on condition.
