Alright I know its been said and argued TO DEATH that a shorter geared tranny is faster on any givin motor whether its N/A or turbo, but I ran across this article on superstreet.com that says the following:
"Those who are into road racing will want to look into matching their transmissions to their engine setups. You can take advantage of a high-revving B16 motor at a road course by using shorter gears for quicker acceleration and keep a longer Fifth gear for better top speed and gas mileage. In drag racing, a turbocharged B-motor should have a tranny with longer gear ratios, like the ones found on an LS tranny, because of the spool-up time of the turbocharger. It’s not as high- or quick-revving like an all-motor car and needs the longer gears to catch up with. A lightened flywheel will also help the equation, allowing the motor to rev up more quickly."
source: http://www.superstreetonline.com/techarticles/27360/
i am by no means saying that they are right or wrong, i'm just trying to get the facts straight. I've heard arguments that have convinced me on both sides so I'm beginning to think that it depends on how much boost you're running and when does the turbo hit full boost, etc etc but I'm not sure. please post the facts with credible data and reasoning so that anyone who reads this will be clear on the facts.
no childish bickering...and if you don't know, don't post.
