Turn signal blinker help...
Discussion in 'Civic and del Sol - EG and EK' started by 93civicracer, Jan 6, 2008.
  1. 93civicracer
    93civicracer Oh, I do a little here and there.
    Texas
    Since I swapped my d15b vtec my front right blinker won't blink when I use the turn signal. But the light WILL come on when I put the lowbeam on, it just won't blink. What could this be? All fuses are fine, replaced the bad ones, ecu has been reset, idk. My interior light isn't working either.
    Suggestions?
  2. 93civicracer
    Texas
    Anyone?
  3. dacheat
    dacheat ..is grounded.
    strongbadia
    ur out of blinker fluid? :shrug:
  4. 93civicracer
    Texas
    lmao seriously I can't figure out why the fuses are all good I just replaced every single fuse in the car and the thing still won't blink when I hit the turn signal on. It comes on when I put on low-beams tho.
  5. 93civicracer
    Texas
    heeeeeeeeeeeeeeeeeeeeeelp
  6. dacheat
    strongbadia
    i am farrrrrrrr from an expert but i'ma go with a short..srsly where are the experts?
  7. 93civicracer
    Texas
    I know...shit I'll try filling up the blinker fluid like you said.
  8. dacheat
    strongbadia
    :lmao: g'luck with that..
  9. charleskwinter
    charleskwinter ignore
    idaho
    your turn signals should have two separate bulbs, one for your parking lights (which come on also with low beams) and one for the turn signal. i am pretty sure your turn signal bulb is burned out :)
  10. 93civicracer
    Texas
    thanks i'll need it that's some hard stuff right there...HEY my carbonfiber/aluminum EURO R pedals just came to the door!!! fuck yea
  11. 93civicracer
    Texas
    Seriously there's 2 separate ones in there? Damn I thought it was only 1. Thanks I'll get to it in a minute when I put on my new pedals :D
  12. charleskwinter
    idaho
    yyyeaaahhh... on the crx for sure and since you have separate turn signals (separate from headlights) i would put money on you having two bulbs in each turn signal housing. not that i am a betting man though...
  13. dacheat
    strongbadia
    no you're right, there are two bulbs. i guess i kinda assumed the bulbs were good :D
