turns over but doesnt start. WTF?
Discussion in 'General Tech and Maintenance' started by floridachill71, Dec 12, 2006.
  1. floridachill71
    floridachill71 Lean and Mean
    J-ville
    guys, i finally get my turbo charged j-spec gsr swap running right (or so i thought), then the next morning after driving it around all night, it wont start. itll turn over all day long, but nothing other than that. there is a strong smell of fuel when trying too. whats up guys? any ideas on what to look at?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    make sure its getting spark
  3. floridachill71
    J-ville
    i tried different spark plugs but no luck.
  4. AHHVTEC
    Alabama
    is it getting spark tho ?
  5. AHHVTEC
    Alabama
    well you can by a tester or you can do it the hard way stick a screw driver in it and have someone eles turn it over wile its being held clost to a metal ground, or just hod it and if it knocks the hell out of you its working lol
  6. racer_XX
    racer_XX New Member
    lmao ahhvtec the good ol fashion hold it and get shocked routine. oh how i have felt that pain. check for spark like he said check fuel pressure and check ur spark plugs check if they smell like alot of fuel. if they are take out all ur spark plugs and blow air into the cylinders with an air gun. u might have flooded ur engine while cranking over now it wont start period. if u have no access to one just take out ur sprak plugs and let it air out for a while.
  7. donnie
    donnie New Member
    high desert
    just like they stated ^^^^ check spark, make sure you can hear your fuel pump turn on. Im sure its something real simple. If you are getting spark , and hear the pump turning on, but no start still. check if fuel is getting to the fuel rail. I had my injector screen get clogged before. Spent a whole day tracking the problem down to the damn injector screens. something so small like that, can kick your ass trying to find it. lol
  8. kaoskustoms
    kaoskustoms Senior Member
    casper wyoming man
    if you have no idea how to check spark you better have some one qualifed look at it.
    not trying to bash just trying to save you a headach
  9. donnie
    donnie New Member
    high desert
    wait, you dont know how to check spark? better start doing some research
  10. jamesA
    ^^^ I'm with all of them. Check your spark plugs, wires, cap and distributor.
    and make sure your fuel pump is at least priming.
    You need 3 things. Fuel, air, and spark.
    (technically four, compression) so do a compression check too!
  11. kaoskustoms
    casper wyoming man
    number four would be timeing not compression
  12. jamesA
    Your timing could be off and it'd still run, horribly, but it'd run. You need compression to have ignition.
  13. racer_XX
    racer_XX New Member
    well if ur timing is off severely then no it wont start.
  14. donnie
    donnie New Member
    high desert
    wow, You built all those cars, and you have to come to a forum to figure out whats wrong with your car. for more help go to getaclue.com
  15. AHHVTEC
    Alabama
    you done all that and you dont know how to check for spark without getting shocked,, well i call B.S
  16. jamesA
    Gimme a break noob... wtf do you think this forum is for?
    Go to www.beadickhead.com if you're going to act like that.
  17. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    OK here it is.
    Take an old spark plug, pull and plug wire of 1 plug and insert old spark plug into plug wire. The set plug don on a metal object, that is grounded in the engine bay. Turn over the car and watch for a spark
  18. donnie
    donnie New Member
    high desert
    act like what? lol. trying to get info from a person that obviously doesnt no shit about his ride. and to help him out? Oh wait, he did build a 13 sec car, 9 sec car, and a 12 sec car.
    you help then .
