TV "receiver" for DTV and Cable
Discussion in 'Computers, Games, Electronics etc' started by K2e2vin, Dec 27, 2010.
  1. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    So, with our cable company about to drop some Fox-affiliated channels and there's also some music channels available on DTV that's not on cable; is there any "boxes" that can switch between the two sources or better yet be programmable?
  2. Briansol
    modern tv's have modes for both of these along with 2 antenna inputs
  3. K2e2vin
    Raleigh, NC
    Do you have to switch modes or is it automatic?
  4. TurboMirage
    lol really?
    you just hit "INPUT" on your remote :shrug:
  5. endlesszeal
    endlesszeal Senior Member
    It depends on how you have the cable hooked up. If its via the old school rf plugs the kind with one wire and you twist it at the ends then you ll have to switch between the cable plug and the oav plug or get a switch. However if cable is hook via hdmi or whatever just hook up oavand select input. It'd be more helpful if you told us if its a modern tv and hour you cable is
    hooked up
  6. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    my vizio has a setting that will allow you to see cable and over the air dtv at the same time. i'm not sure how it works because i've never tried it..
  7. Briansol
    ^ both my lg and samsung are set up this way with the QAM tuner
  8. K2e2vin
    Raleigh, NC
    That's for input source. The TVs we're using you have to go to Setup and change the source signal from Cable to TV. This would work fine for the digital cable box but the we're dealing with analog cable as the primary source.
    I'm looking for something like that; some sort of cable box or dtv box that'll do the work automatically. I guess it's a combination of both(cable+dtv converter box).
    We're trying to do this on our older (crt) TVs we have around the house which already just use analog cable. Even then, most new TVs have just one coax input and the rest is RCA.
  9. Briansol
    AFAIK, analog cable no longer exists.... hence the whole digital tansition....
  10. GSRCRXsi
    MD
    the transition isnt complete for most (if not all) cable providers.
    the govt mandated transition is for OTA broadcasts only.
  11. K2e2vin
    Raleigh, NC
    :werd:
    Our basic/standard cable is still analog.
  12. K2e2vin
    Raleigh, NC
    Does any of your TVs have dual RF inputs?
    It looks like either way I go, I'd have to purchase a box and switch inputs. The analog/digital selection seems to be for antenna only(even if it could "read" analog cable, I'd have to unhook it and plug the antenna to get OTA signals).
  13. GSRCRXsi
    MD
    do the Satellite STB's not have a component or composite out? or only RF/coax out? satellite should have a STB. that way you can just run the analog coax for cable, and a video input for the Sat STB.
  14. K2e2vin
    Raleigh, NC
    Difference is, satellite STBs have a coax-in for antenna along with input for satellite....cable STBs only have "cable".
    One of the TVs has just coax-in, so I'd need a switcher or hook up a VCR/DVD player to it. I'm really trying to find a "all-in-one" solution. One thing, though, is the DTV boxes have analog pass-through. I didn't think about this before; but maybe using a combiner would work? I know when my brother hooked up the DTV box to the cable, it didn't pick up any channels at all; so hopefully there's no interference.
  15. GSRCRXsi
    MD
    so is the only thing keeping you from the solution i suggested, just that 1 TV that only has coax-in as an input? if its THAT old, maybe consider replacing that one TV with something that can do a coax and composite input?
    im a little confused here. could you make a diagram in paint real quick to illustrate the problem you are having? my gf's parents have direct TV, and their basic STBs (non HD which im assuming thats what you have) have just a single coax in (from the dish) and a single coax out(to the TV) or a composite out (to the tv input).
  16. K2e2vin
    Raleigh, NC
    They're not really old, just cheap. I'd like to keep it that way.
    Just put it this way: I have an antenna cable and a cabletv cable for one input. Some satellite STBs have in input for both satellite and antenna. like this:
