Tweeters into 2003 Accord DX
chambl
I recently got a 2003 Accord DX (Canadian version). I noticed that the speaker grilles for the tweeters were at the extreme corners of the dash, but I'm not sure how I could go about installing tweeters. Would anyone know what size tweeters could work, and how to go about installing them? Might anyone recommend any brand of tweeters? Thanks a lot!
do the covers just pull off?
otherwise I don't know how you will get at them
check www.crutchfield.com
you should be able to get the speaker specs from there as far as what size
if you just but any decent set of 1" tweeters they should work but will probably require a little modification. like using some pipe straping to support and angle the tweeters.
good luck
The covers do just come off, and there are wires there waiting. The only problem now is the cover. It has no holes. I either have to make some holes in the cover or replace them... There's also no mount or attachment for the tweets, either in the dash or on the covers. I suspect that the tweets are attached to the speaker covers in higher models...
