two problems.
Discussion in 'General Tech and Maintenance' started by MthaFuknGreen, Mar 2, 2009.
  1. MthaFuknGreen
    Lodi, CA
    1. my idle acts the exact opposite of what its suppose to do. when the car is cold, the idle is low, hovering around 800. at this point, the car acts like it wants to die and most of the time it does unless i rev it up to about 1500 for about a minute or two. then when it warms up, it hovers around 1500. it doesnt stay put at a specific number when its cold or warm. its not exactly surging, but itll kinda bounce around within about 100-200 rpms.
    2. my alternator pulley squeels like a bitch. it does it off and on. sometimes it will, sometimes it wont. the only time its guaranteed to do it is when i add some electrical load i.e. the lights. most of the time, i just have to rev up the engine to about 3 or 4k and itll stop for the moment. it really only does it at lower rpms.
    no codes or anything..
    anyone have any ideas?
  2. MthaFuknGreen
    Lodi, CA
    heres a video..
    the idle is even worse when i havent started it for a few days.
    it usually dies.
    YouTube - DSCN2946
  3. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    most cars have an idle adjustment, look up the procedures in a manual for the prelude.
    perhaps your map sensor could be going, but im not seeing code, at the same time its sounds like its misfiring.
    alternator squeal is usually a belt dieing or in need of adjustment, or less oil on the ribs, but I'm guessing you already know that.
  4. Ethan
    Ethan Well-Known Member
    idk but that shit sounds horrible. Is that a knock i hear?
  5. MthaFuknGreen
    Lodi, CA
    i tried adjusting the idle, i cant because it wont stay still.
    and the belt is brand new.
    yeah, its my exhaust knocking on the frame.
    lol
  6. MthaFuknGreen
    Lodi, CA
    and when i shift it into drive or reverse, it dies immediately.
    havent tried it while its warmed up yet, but when its cold.
  7. Ethan
    o shit i was bout to say. lol
  8. disableddan
    disableddan Crazy Insane
    Edmonton Canada, Eh?
    lol I forgot how annoying having the exhaust bouncing off the car is... ugh!
    All I can say is damn, that thing sounds fucked right up.
  9. Z6CRX
    Pittsburgh, PA
    egr gunked up? hamsters in the intake?
  10. Z6CRX
    Pittsburgh, PA
    I also noticed the lights are dimming really bad under low revs.
    alternator maybe? perhaps battery?
  11. MthaFuknGreen
    Lodi, CA
    i disconnected the plug on my alternator and there was a bunch of white shit inside it.. i dunno. my alternator keeps it charged though. i think it may be my terminals.
  12. Ethan
    it sounds like what happend to my civic... and i got white shit all over my alternator too. is you corrosion or just some random white shit? like someone duped some coke on that shit.
  13. MthaFuknGreen
    Lodi, CA
    its not corrosion.. theres like white speckles all over the pulley too.
  14. Ethan
    yea when i rip my civic apart ill show you a pic i got the same shit. idk what it is i thought someone duped something on it. and im having like the same exact problem. but my shit finally failed.
  15. klyph
    klyph Dismember VIP
    North Pole, AK
    Loose belt or bad alternator. Which could be part of the idle problem.
    Tighten the belt, have the alternator tested, check the main grounds of the system. Once the charging system is fixed let us know how the idle situation is.
  16. MthaFuknGreen
    Lodi, CA
    my belt was tight as shit. i loosened it as much as i could today, but its still too tight to pull off.
    and it stopped squeeling for a little bit, then it starting squeeling when id rev it higher which is the opposite of what it did before.
    i took off the power steering pump when i was fucking with the alternator cuz i was trying to get the bolt that threads through the stud and into the alternator for the adjustment nut and some of the fluid dripped out onto the pulley and i think that might have been what kept it quiet for a minute..
  17. klyph
    klyph Dismember VIP
    North Pole, AK
    You sure it's not the power steering belt squealing?
  18. MthaFuknGreen
    Lodi, CA
    i took the power steering belt off.
  19. boostin4fun
    boostin4fun Boosted ls/vtec ohh yeah!
    Omaha
    The bearing in the alternator is probably shot. I just replaced the alternator in my sister's prelude, it was doing the same thing. It would squel like a bitch for a while then stop. I threw in a rebuilt one and it took care of that problem. As far as the idle problem, do you have a check engine light?
  20. MthaFuknGreen
    Lodi, CA
    no lights of the engine checking nature.
