I have a 94 hatch with V-Tec Del Sol engine & suspension & axles.
I want to switch over to the Integra Type R 5 bolt axle hubs. I know that the rear axles are larger on the DelSol disc than on the hatch drum axle because I had to replace one hub and the original drum hub bearing wouldn't fit onto the larger Del Sol rear axle.
Will the Teg "R" front hubs fit the Del Sol bearing and (B16A) outter CV joint?
Will the Teg "R" rear bearings fit onto the Del Sol axle shaft?
With this change will come brake mods to accomodate the new hubs. What fits?
I hate to change calipers unless they are aluminum. The brakes now are great.
Can I just get redrilled rotors?
