type-r brakes, on a civic
civicext
Member
whats going on every one? if any one out there can help me with this prob i been working on?i been trying to get a strait answer from some one to see if the hub part of the type-r will fit the hub of a civic with out having to get the turning knockles.. it would be a cheaper way out of doing the swop but no one can give me a strait answer on it. if any one can hit me up that would be thank full :ph34r:
thanks
I used the whole front knuckle, but from what I have heard, as a matter of fact this was discussed on another forum, that they bearing and hubs do fit in the Civic knuckle, a guy was trying to cheap out and use CRV hubs, and found them to be 1.5mm larger, so he used the ITR ones instead. But, it is a lot more work and from what I have found it is cheaper to find GSR or ITR knuckles. On the rear however, you don't have to change the whole trailing arm, the spindles will bolt right on to your trailing arms.
